Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
Find and Select 3d Text
When I use the find and select dialog box, I can't find "3d text". I find text, however, but this is not the same. How can I use this dialog box to find 3d text?
1 REPLY 1
David Maudlin
famadorian:
Text 3D is an Object, so set the criteria for an Object with "Text" in its name.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
