‎2017-06-2312:15 AM - last edited on ‎2023-05-2408:30 AM by Rubia Torres
‎2017-06-2312:15 AM
All my walls should be straight walls, but I'm finding all kinds of non straight walls. It's spooky. I'm trying to be extra careful now to always hold now shift, but I still find them. Is there a way to disallow angles less than 45 degrees?
Is there a way I can find all these walls that are wrong?
I want to find all walls that I somehow screwed up, where they have an angle of 1 degree or something.
Holding down SHIFT is only a good idea if the Snap Guides are turned off (or set to turn on after a longer delay), otherwise you may be compounding the problem since they often use the "bad" elements to set the angle.
