Finding Non Straight Walls
All my walls should be straight walls, but I'm finding all kinds of non straight walls. It's spooky. I'm trying to be extra careful now to always hold now shift, but I still find them. Is there a way to disallow angles less than 45 degrees?
Is there a way I can find all these walls that are wrong?
I want to find all walls that I somehow screwed up, where they have an angle of 1 degree or something.
Look for the "Element Orientation Check" label on BIMcomponents.com
https://bimcomponents.com/GSM/Details/21086
Holding down SHIFT is only a good idea if the Snap Guides are turned off (or set to turn on after a longer delay), otherwise you may be compounding the problem since they often use the "bad" elements to set the angle.
Here's a relevant thread: http://archicad-talk.graphisoft.com/viewtopic.php?t=5349
Richard
AC26 (since AC6.0), Win10
