2016-03-1411:34 PM - last edited on 2023-05-2304:18 PM by Rubia Torres
2016-03-1411:34 PM
Please refer to attached file. In a kitchen wall, using solid operations I have subtracted an opening and then, in the opening, used the wall tool to draw a profile of a rolling counter shutter and serving shelf (could not find a BIM object on-line) that I created as a profile. The shutter shows perfectly in the section shown in the attached file, as well as in 3D and in elevation.
The shelf is at 3'-5". I have set the floor plan cut plane at 4' as shown in the image but cannot see in plan the shutter. Assistance will be greatly appreciated.
Why you use a Solid Element Operation instead of a regular opening?
Is a complex shape or something? If not try doing the opening with a regular opening and check if that works. And also you could try doing a custom window of the shutter, that might work.
I really don't know why is not showing.
Solid Element Operations do no show in plan.
Try using an empty window opening to cut the hole in the wall instead.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
I merged the duplicate posts but it seems you have the same answer from both.
