Floor plan different than 3D (offset)
Hi Guys,
Im having this problem with my floor plans being different from 3D views, I have tried adjusting the offsets in railings settings.
I have put rods in for reference.
Anyone know what im doing wrong?
Thx
6 REPLIES 6
Can you upload another view of the 3D. Now it is a view from above, I would like to see a view that is more from the side to get a better understanding of how it is generated in 3D.
Thanks, i have altered the model since posting this, so there will be some inconsistencies.
Seems to be a 30mm difference
Bump.
Would love it if someone has a solve for this or experienced similar, I've tried everything in the railing settings, going left to right, right to left, offsets on may railing settings.
3D view working properly on this part of the project would be great.
Thx
The views you have linked do not indicate what you are wanting to achieve. Can you attach an image and plan marked up with what the issue is, preferably attached image as linked images on external hosting sites expire and are a pain to use.
Regards
Scott
