Display malfunction of Graphisoft ID dashboard
Learn more
For help in creating differend window
I need a window like in the pic (I mean it's panel)
How can I create or make something like that?
4 Replies 4
See this link explaining how to make your own custom window.
http://www.archicadwiki.com/TechNotes/Creating_custom_windows?highlight=%28window%29%7C%28custom%29
Peter Devlin
thanx for help, but I didn't find any information about making these:
Step one in the referenced article says build the window with
slabs, walls, and other Archicad tool elements. This is meant
quite literally. In the case of what appear to be exterior trim
elements in you image, you would draw these as slabs with
their top surface elevation at zero.
Peter Devlin
thanks, it seems i have understood...i hope so..
