ā2019-10-01
04:02 PM
ā2023-05-24
08:10 AM
Rubia Torres
ā2019-10-01 04:26 PM
ā2019-10-01 04:35 PM
ā2019-10-01 05:19 PM
Andy wrote:Set the concrete portion of your profile to 'core' (vs 'finish' or 'other') and set your partial structure display options for the plan view to show 'core only' (or 'core of load bearing elements' if you've also identified your foundation walls as load bearing and need to filter other non load-bearing elements out).
when I set the cut plane in my view to cut through the stem wall only, the other materials in the wall were showing up in plan view as well. Is there a way to turn off or not show certain items / materials in a complex profile?
ā2019-10-01 05:33 PM
ā2019-10-01 10:40 PM
Andy wrote:
Thanks Karl. Would I then add the cut fill pattern of the stem wall as a separate fill manually?
ā2019-10-02 12:07 AM
