Frank gehry building style
hello every one here , n it's really good to join ur forum
then i just wanna ask bout very important thing n that is what if i wanna make or creat a building like Frank gehry style tenden n random seekin wall n as like by using Archicad 12 or 13 , so i think as i know really it's hard to use it for this style of building , n my question is :Is there any easy way to create it
thanx
4 Replies 4
Dwight
Yes, the swoopy bits are easy.
Using a combination of specially formed complex profile walls, beams and columns with slicing by Solid Element operations, you can model the irregular curved swoopy things.
complex profile wiki
Solid Element Operation
However, there's no way to wholistically make a structure that is organically editable in any direction like a mushy blob. You build a library of likely profiles and edit them as you go.
Dwight Atkinson
andrewzarb
Once again Pandora's box has been opened..
Rafal SLEK
Box with Pandora 🙂 :
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
Petros Ioannou
well , if you want Gehry-style building, then why not use Ghery's software?
http://www.gehrytechnologies.com/
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
