Funky Windows
hi guys,
i am looking to make some funky windows at angles on the facade, i know this should be made illegal but below is an attached image of the Autocad elevation i originally worked on.
Could any one tell em ifthis type of windwow design can be acheived and how because i hav been through all the windows and there is only your basic shapes
Thanking u in advance
4 REPLIES 4
Dwight
It is a complex solution.
Page 189 of the Archicad 10 reference guide shows the basics of saving an element made flat on the floor at elevation 0 as a window or door.
In principle, you create the goofy window shape and save its 3D view as a window.
The problem is that the program will cut a rectangular wall hole for that goofy shape when placed in a wall. You need GDL to fill in the irregular bits.
If this is a one-off, you can build-up the irregular window form gap into a rectangle using a slab with the same material as will appear on adjacent wall surfaces.
The attached image shows the goofy windo with infill - the easiest solution.
Dwight Atkinson
Srinivas
There is a Tip for filling the irregular bits here.
http://www.archicadwiki.com/TechNotes/Creating_custom_windows?highlight=%28TechNotes/%29%7C%28TechTi...
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Dwight
And a simple tip it is, too.
Dwight Atkinson
GUYS THAT IS BRILIANT
THANK YOU SO SO SO SO MUCH
GREAT HELP....
I THINK I LIKING THIS PROGRAM MORE AND MORE!!
MERRY XMAS
