toman311
Gable Roof Corner Joinery
I attached a picture of the situation. Is there any way to join these to gable roofs so the eaves aren't crossing one another and, instead, terminate into each other?
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
rgarand
You should trim each roof to each other and this will solve your problem but create another since you are trying to create a roof eave/fascia with your roof as well.
These days I draw my roof plywood sheathing (5/8" thick) and draw my eave/fascia as a wall profile. More work, yes, but better detail and more control. Plus you can draw a section through your wall/roof and it should look just like the detail you want. Which translates into less work when detailing. So everything works out in the end.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
