Gradient Fills ArchiCAD 17
Where are the gradient fills in AC17?
For some reason they don't show up in a brand new file in AC17.
I can however copy them in from another AC17 file, but they still don't show up in the FILL TYPES setting dialogue to change the name etc.
Any ideas?
thanks.
4 REPLIES 4
They are not fills that you can edit or rename in any way.
They are simply a 'Lineal' or 'Radial' fill that you choose the colours and extent of the gradient when you place them.
They can only be placed as a 'Drafting' fill though.
Can't be used for Cut or Cover fills so can't be used on any 3D elements.
Thanks Barry,
I did manage to rename them within the Attribute Manager.
Mike
Actually not entirely true.
You can rename them in the Attribute Manager and you can 'append' to create a new gradient fill but there isn't much point as they will be exactly the same as the originals - just with a different name.
fuzzymike2002 wrote:
Thanks Barry,
Mike
You beat me to it.
