Gradient fill in ArchiCAD
Another way would be to create the gradient fill through Archicad. We have done this in the past and it has worked. Create the fill by drawing a generic arced wall and use a 3D vectoral hatching to show a pattern on the wall in a elevation view. Create a elevation showing the outside of the wall. Open the elevation and select the wall (it will have a gradient pattern applied due to the curve). With the wall selected, copy to the clipboard. From there, create a new symbol fill, paste the image, and scale the settings as needed to show the design. By setting the fill origin and layering the fills, this will give you a gradient effect without using the other programs.
0 Replies 0
