Llian
Grid and Origin
I drew a polyline and the x is on the 0. How do I align it with the background grid that is set to 100, 100?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
David Maudlin
Lilian:
There are two things to look at:
1. The User Origin is not aligned with the Project Origin. Open the Coordinates Palette and double-click the Set User Origin button (left-most button) to reset the User Origin to the Project Origin. (There is probably some other way to activate this command, this is just the way I do it.)
2. You have switched to the Rotated Grid option, which can be set with an offset but 0˚ rotation under Grids & Backgrounds.... Switch back to the Orthogonal Grid option.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
