‎2016-02-03
01:40 AM
- last edited on
‎2023-05-23
02:23 PM
by
Rubia Torres
‎2016-02-03 04:52 PM
‎2016-02-05 12:59 AM
‎2016-02-07 07:16 PM
‎2016-02-07 11:10 PM
‎2016-02-08 02:41 PM
S wrote:You can do this is one step: select the Roof, right-click to get the context menu, and select Relink Home Story..., this will bring up a dialog box that allows the user to change the element's Home Story without changing its height relative to Project Zero.
After building the model I go & select all the roof's & change their home storey to 'site'. Then I change there distance 'to project zero' so they are still siting in the correct position.
‎2016-02-09 03:45 AM
‎2016-02-10 02:20 AM
‎2016-02-10 02:32 AM
‎2016-02-10 03:45 PM
Scotty wrote:Right, the Home Story has been changed, so the Roof may only be visible on its Home Story. Select the Roof (go to its new Home Story to see the Roof, or select in the 3D Window) and look at Roof Settings > Floor Plan and Section > Show on Stories, there are options for showing the Roof on more than its Home Story.
David Maudlin wrote:'You can do this is one step: select the Roof, right-click to get the context menu, and select Relink Home Story..., this will bring up a dialog box that allows the user to change the element's Home Story without changing its height relative to Project Zero.'
Hi David, I tried this, but then my roof was no longer visible in my roof plan?
