Site Plan
Hi, I am using the Australian template and would like to know the best way to go about setting up a view for a site plan. For example, so that the view is showing the roof plan plus the site and planting. Any advise appreciated.
12 REPLIES 12
Erika Epstein
One way is to have two drawing overlaid on your layout. One is the site plan story set to your Site Plan Layer Combination. On top of it you can have a Roof Plan drawing set to your Roof Plan Layer Combination.
This works well when your roof story is not on the same story as the site plan.
If however you want to show the exterior walls with just a dashed line showing the roof outlines, then you can trace the roof outlines on a Site Plan specific Layer.
It all comes down to what you want to show.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I am curious to see ways that other people create site plans, as I think there is a lot of different ways that can work.
Erika's way is one way I have used in the past, using multiple saved views and placing on layouts.
I have also used different layer combinations and cut plans to get elements to show on the relevant storey.
Hi TiggerF,
In the case you described I mostly use 3D Document option with Show Down to stories option. Give it a try.
Here's an example:
S A Harrison
Scotty,
After building the model I go & select all the roof's & change their home storey to 'site'. Then I change there distance 'to project zero' so they are still siting in the correct position.
That way I have the roof's in the correct position on the model & appearing on the 'site' storey to complete the site plan.
Sean Harrison
AC18, Windows 10
David Maudlin
You can do this is one step: select the Roof, right-click to get the context menu, and select Relink Home Story..., this will bring up a dialog box that allows the user to change the element's Home Story without changing its height relative to Project Zero.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
S A Harrison
Thanks David, that's a good little 'time saver' for me.
Sean Harrison
AC18, Windows 10
David Maudlin wrote:'You can do this is one step: select the Roof, right-click to get the context menu, and select Relink Home Story..., this will bring up a dialog box that allows the user to change the element's Home Story without changing its height relative to Project Zero.'
Hi David, I tried this, but then my roof was no longer visible in my roof plan?
Another question relative to this is, can I just have a cut plane that starts at the highest point of the site down to the lowest, showing everything?
David Maudlin
Right, the Home Story has been changed, so the Roof may only be visible on its Home Story. Select the Roof (go to its new Home Story to see the Roof, or select in the 3D Window) and look at Roof Settings > Floor Plan and Section > Show on Stories, there are options for showing the Roof on more than its Home Story.
