Grid snap does not work properly in AC15
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-11-24 09:05 PM
2011-11-24
09:05 PM
For example i have 1'x1' grid. My grid snap is on, and is set to snap to construction grid.
I click at the edge of a wall and move it down 1 grid space. Instead of moving it down by 1' at 90 degrees, it other angles.
and when i zoom in, i can see that it didn't snap at the grid, but the snap point is a little off.
Has anyone faced this problem?
32 REPLIES 32
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-29 03:46 AM
2012-03-29
03:46 AM
sarahric wrote:Did you start dragging with Snap OFF, then turn it ON to position it?
Also have the problem that the drawing I'm given is not on grid. I try to move elements with grid snap on, they just snap to the grid snap distance from the object, and not to the grid on screen. ie my grid snap is set to 1 mm, the wall is at 1.77mm and I try to pull it to the grid at 2mm but it drags to 2.77mm. Meaning I can't fix the drawing.
Actually, ignore that. I just did a test and it works correctly for the main grid, but not the snap grid.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-29 04:44 AM
2012-03-29
04:44 AM
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-29 05:56 AM
2012-03-29
05:56 AM
sarahric wrote:Of course you can.
If you want to snap to the main grid just turn it on and drag to the point you want.
But if you want to snap to the "snap" grid then turn your grid snap on and place a hotspot on the location you want to move to.
Turn the grid snap off and now drag what you want to the hotspot.
Now turn your grid snap back on.
- « Previous
- Next »
- « Previous
- Next »
