‎2005-12-24
11:18 AM
‎2023-05-23
05:18 PM
Rubia Torres
‎2005-12-25 07:39 AM
miker wrote:Make the grouped objects into a library part. It will convert to a block.
I want to make the translator to transform the grouped objects to blocks ,when i create a DWG file ,but can't find the solution.
Anyone of you know how?
Thanx
‎2005-12-25 02:08 PM
‎2005-12-27 06:15 PM
miker wrote:AFAIK AutoCAD does not have Groups? So there is no corresponding entity, except the library part.
Thanx Djordje
Although it would be very convenient if there was an option in the translator to automatic do this,at least for 2D objects(lines, etc)
‎2005-12-28 01:41 PM
‎2005-12-28 02:37 PM
‎2005-12-28 07:08 PM
Fmr wrote:
If you mean several ArchiCAD objects group together transformed in ONE block AutoCAD, I think that the good way to do that is to Create One Object ArchiCAD which need to be as the block you want in AutoCAD.
HTH
‎2005-12-28 07:44 PM
‎2005-12-28 11:16 PM
‎2005-12-28 11:23 PM
Fmr wrote:Just a french "Coucou"
Good night miker
