Guastavino Vault
How would I model a guastavino vault?
I know roughly how to create the simple barrel vaults, however I'd like to be able to create a kind of roof structure which curves down to the ground/columns.
Thanks.
16 Replies 16
Mesh generator is your answer...
Is it possible with the Shell tool?
Anyone?
Erwin Edel
Probably not with a single shell, but perhaps by combining multiple shells into the one shape.
http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
good starting point?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I think that archicad can´t do that... maybe other better program like Revit
Sorry but the curtain wall doesnt fit with the vault ... more haste, less speed
No more than 10 minutes, archicad + artlantis include.
Cinema 4D plug connection to ArchiCAD in will do the job pretty easy.
Thanks for all the response.
I think Revit would be easily able to create my vaults. Unfortunately, it seems ArchiCad isn't quite capable at this point.
But if I was to create my vaults in Revit, would I take it back in to ArchiCad as an object?
Thanks
Thanks.
Try this exercise with OBJECTiVE. I made the attached image in a few minutes using its profiling, bending, and cutting tools.
Ralph Wessel BArch
Central Innovation
With archiforma and the "Coons Surface" is a smart way to do too.
