HELP - ROOF
Hi
I am a newbie and need help with a roof. My project involves ground and first storeys. I need the roof to start above the first story, angle on the ceiling of the first story and finish on the floor of the first story. How can i stretch the roof as you can see in the image is not reaching the floor.
Secondly, this roof is meant to be a thatched roof. How do you do that?
Thanks in advance!
4 REPLIES 4
skukadia wrote:
Hi
Select the roof and adjust the height in the Info box until it is at the right level. If the roof is assigned to a story (rather than story being selected "automatically") it will still display on the plan as it does now.
Thanks in advance!
I have approximated this in the past with a thick roof with perpendicular edges, and created a material with a thatch-like texture and a suitable vectorial hatch for elevations. I can't post a picture unfortunately, as this was done at a previous workplace.
Thanks alot s2art
Heres my render with the roof done. I figured i can add the thatch later in my final rendering software
Erika Epstein
skukadia,
Did you forget to attach the render?
There is a size limit for photos, but you can usually make a pdf that will be an open-able attachment here
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yes sorry i tried uploading but i couldnt heres 1 of the pictures
Thanks for all the help people
