HI-RES picture in Archicad 9
I want to save my groundplan as picture, but pictures have bad quality. How to save it in highest quality???
I have to work with this in photoshop later.
And 72dpi is very small number...
Many thanks!!
and sorry for my english.
Print to PDF.
To give you a bit more info. . .
Print to PDF from plotmaker, and set your output at the desired size and print resolution. I.E. if you're wanting to print an ARCH D print at 266 DPI from Photoshop, then set your PDF settings to an ARCH D 300 DPI from Plotmaker (I recommended using Plotmaker as you can lay out your page with a WYSIWYG interface).
When printing RASTER images always remember: It's easier to decrease resolution, but when you increase it your print will be more pixelated (blocky).
If your pdf printer is correctly configured, you can bring the PDF into the more current versions of photoshop at whatever DPI you choose, because plotmaker sends the data to the PDF as vector (equation) data instead of raster (pixel / square) data.
Rick Thompson
You might experiment with zooming the plan to max (1000%) and copy pasting into photoshop. It saves a few steps and more than likely you want see any difference. In photoshop you can set the resolution to 300. This only works if you don't need the image too large.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
