HOW CAN I CHANGE THE TEXT UNITS?
DOES ANY KNOWS WHY THE TEXT BOXES DISPLAYS THE TEXT UNITS IN FEETS AND SOMETIMES IN POINTS IN THE SAME PROJECT FILE?
I WOULD LIKE TO HAVE ALL THE TEXT TO BE PLACED OR EDIT THE EXISTING IN POINTS ALL THE TIME AND APPARENTLY I CAN'T SO I HAVE TO PLAY USING TRAIL AND ERROR WITH THE FONT SIZE ONCE IS PLACED...HOW CAN I MAKE THE TEXT UNITS CONSISTENT?
I TRULY APPRECIATE ANY ANSWER ON THIS ISSUE!
Link
The text can be set to Fixed or Scaled in the Text Settings dialog.
Fixed will be in Points, because it will remain fixed, no matter what the scale is. Remember there is 72 Pts in one inch.
Scaled will be in feet & inches, because it will scale relative to the scale of the model.
Does that solve it for you?
Link.
You're more than Right!
Problem Solved
Thank You!
