2009-06-24 04:36 PM
2009-07-27 09:44 PM
2009-08-26 07:12 AM
2009-08-26 09:04 AM
David wrote:Beg to differ here. (I know what you say is Adobe's official standpoint, and might be true for standard drawings, but..)
By default, Adobe Acrobat saves .PDF files in legacy file format. Depending on which version of Acrobat you have, the legacy format could be saved as far back as version 5.0. This creates considerable file overhead. If you set your Acrobat save function to be a later version, this could reduce you file size considerably. Also, check the bitmap/raster conversion settings and set the compressions to as high as you feel comfortable (for the least loss of output quality).
2009-10-14 05:07 AM
2009-10-14 04:19 PM
tambi wrote:I can relate fully to this dilemma. I started drafting in the late 60's in high school, so line quality and "snapping out things" was the only consideration. Once I started with AC (4.5) you didn't have the tools we now have so I always made elevations dead to tweak the line values. I had a lot of pride in the quality based on those precepts. But, that's just ego hanging on to the past
This is a great discussion. The small office I work for has always turned all elevations and sections in drawings .... My boss has a real thing for lineweights so I need to get them to work the way he likes in order to introduce more 3D into the office.
2009-10-15 07:43 AM
Rick wrote:I was halfway through a lunch at a conference that had nothing to do with either architecture or computers when I realized the guy sitting next to me, Dan Drake, was one of the original founders of Autodesk.
2009-10-20 06:58 PM
Rick wrote:Rick, what are you doing to make elevation views read better? I still don't use live elevations, because I find that lineweight is the best tool for conveying depth / plane changes.
I now like what I turn out much better than what I use to, but they are different. You can generate drawings better reading (in my opinion) in much less time.
2009-10-21 06:33 AM
2009-10-26 07:27 PM
jbArch wrote:Sorry for the delay, out of town.
cheers,
JB
2009-10-26 07:36 PM
