HOW TO PUT IMAGE INTO A 3D MODEL
hi all,
how do you guys put an image into 3d model? for exapmle, how to make a virtual painting or a label with text. to be more precise, i want to add that plain 2D picture into a project just like a poster on a wall.
any help would be helpful.
10 Replies 10
Dwight
Picture 10 object
Dwight Atkinson
... and have the image you want loaded with your libraries, calling it up with the Custom parameter.
well, i should have told you that i am totally new, hence "picture 10 object" is smth i don't get šŸ˜• could you be more precise? do you mean i should add it as a texture???
Dwight
You asked for a method to place a single image in a model.
1: place desired image in Library by making a new folder in the library called PICTURES.
2: Reload library.
3: Locate "Picture 10" object using Object dialog box and searching to find it: Path might be: Object Library>Pictures and Texts> Picture 10
4: Place object.
5: Open object dialog.
Set Custom picture name to your picture's file name.
Picture will represent in rendering.
Dwight Atkinson
Thanks a lot, Dwight!
since i came up with a result because of your advice. there is smth else i want to ask.
is it posible to make a clear visible wall coners? i want them to work on explore mode, cause now it's unclear if the wall is square or not...
Dwight
Dwight Atkinson
heh, it's probably my english...
here are two pics that explain what i want. Do you have any ideas how to do this? thank you in advance!
Dwight
3D Window Setting: Set Contours to: Draft or Best
Dwight Atkinson
thanks again!
