Learn more
Half round windows
I have a building with a half round roof, and I need to construct a window from floor to roof - have tried the half window object but unfortunately I can't 'flatten' it to suit the width and height.
So I read a forum post here stating to try create my own window using the slab tool and saving it as a library object so I'm trying that out. But I can't seem to edit/adjust the window while in section view - is this not possible? If not, what are some other methods I can use to get this window I need?
Thanks.
2 Replies 2
Cadimage's window builder will do arched windows easily, and as a kiwi student it should be free for you.
http://www.cadimageworld.com/tools/design/doorswindows
If you create your own window you will not be able to adjust it.
You need to create it exactly as you will need it.
Any changes and you will need to create it again.
