Have any way to convert ArchiCAD14 gsm to ArchiCAD13 gsm?
For example this archiCAD 14 gsm
7 REPLIES 7
When open it with ARchiCAD 13 It will show this dialog.
If it possible to fix it?
Like this
The only time library parts were backward compatible was from 7 to 6.5. One way to do it is to remake the part in the earlier version by copy/pasting the scripts. You will have to rebuild the parameter list manually though. I seem to recall reading that it is possible to export the part(s) as XML from one version and import that into a prior one but I am not sure about this.
owen
Try this:
1. Add the Library Object to the Embedded Library in any AC14 file
2. Save As>ArchiCAD 13 Project
3. Watch the progress meter ... you should see one of the stages is 'Converting Embedded Objects' or something to that effect
4. Open the resulting 13 Project in AC13
5. Extract the object from the Embedded Library to wherever you wish
6. (Hopefully) Voilà .... one AC14 object converted to AC13
This has saved my bacon several times after forgetting which version of AC i was in when editing an object used by 13 files
hth,
owen
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Thank you very much for this "GOD solution"
It's work!!!
Can you think this? Very surprise.
This is great. Glad to hear there is finally a solution for this. Thanks for the heads up!
Matthew , Thanks to you too.
