Have problem in section and converting to autocad
Hi there i have a problem when making section
i see line is not a single line but divided which is really problem as you can see in the image
second when i converting it to autocad it convert it with many hatches but i select fill and ctrl+a to delete all fill but this will also delete fill in slabs i did that because file is heavy in autocad with this many fill in sections
please help me
Is the plan view of those lines a curved element? When converted to Acad curves are rendered as several short lines approximating a curve.
In terms of fills, set the model view to override fills with no fill, save this model view as Export-nofill. Now when you export, it will not have as many fills - maybe none.
Find an Autocad forum, maybe more help on that end.
Snap
