Having problems with snapping lines in 3D view
I want to make several elements snap together in 3D view as I can't do it in 2D, but only a few of parts actually snap. It's weird because they were all created in the same way but only the odd one or two will snap onto each other.
Attached is a screenshot of what I want to snap, the red line indicates where the join is.
Thank you for your help
10 REPLIES 10
Anyone please ?
Erika Epstein
Select the front object and move it into place.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I have but I can never get it lines up perfectly. My other thread, shows why it needs to be aligned perfectly, but I'm having trouble with it all for some reason
Erika Epstein
I haven't followed that entire thread, but if there aren't nodes after all the trimming where you want to align them, then you may have to do this in section windows.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Windows ?
Erika Epstein
The window that the section opens in.
I place a lot of what I call working sections throughout a project. They are a favorite so on a non-plotting layer. Place (and delete when done) as many sections as you need move your elements to proper alignment.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Ok, I know where I've gone wrong ( again )... Going to start from scratch.
How can I add an offset to this Fill without it ' going off shape' As you can see when I drag the cursor the profile is at an angle, can I add something to make all offsets from that line straight as illustrated by the simple line to the left of the angles line.
Thank You
Edit: I believe I need to add a tangent to the line so that it is the same width when extended. Not sure how to do that !
SeaGeoff
Ace
How about this:
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
Yeah, that what I did thank you.
I don't mean to be rude to Ralph who has helped me a lot on the other thread, but could you please help me with it as he's not online...
It;s setps 5 and 6 I'm not too sure with : Click here
Thank you to all who have helped me with my project so far, it's amazing how much you can learn daily !
Thank You
