2006-09-2612:30 AM - last edited on 2023-05-3001:44 PM by Rubia Torres
2006-09-2612:30 AM
When I export to dwg from a sheet view via publisher everything exports except for the layout's title. I can't find a setting for it to export. I have played with all of the settings I can think of but the heading title is not there. Is there a setting I am missing?
My guess would be layers. There is a conflict between modelling and layout layer display (i.e. sometimes layouts pick up your latest layer combination). Put everything in your Master on the Archicad layer, (lines, logos, text, everything) and it should always show.
No, it wasn't layers. My masters have everything on the archicad layer...
I just opened the master and that was it. When I went back to layouts all of the titles showed again. I double checked to make sure it wasn't a layer issue as you mentioned but all the info on the masters is on the archicad layer.
I will see if it happens again and pay closer attention to what it might be.
And to follow up. It definately wasn't an accidental toggle of that switch because some master layouts were visible while others were not. That toggle makes em all invisible. I like knowing about it though.
