Help!! Need to open a version 6 pln file?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-07-11
04:47 AM
‎2023-05-25
05:59 PM
Rubia Torres
‎2013-07-11
04:47 AM
job I did in 1999 - 2000 on version 6.
I found my AC10 CD but don't know for sure if it will even run on a
windows vista ultimate 64 bit system.
I think I read somewhere that either 10 or 12 would open these older version pln files, but don't know for sure.
Can I open this file with AC10 on my current system (see below) and
if not is there any way I can open and use the data from a version 6 file?
I would hate to have to go up there and do as built dimensions again!!
I know the whole house is drawn correctly on the version 6 pln file!
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-07-11 05:13 AM
‎2013-07-11
05:13 AM
I have version 10 installed on a Windows 7 64 bit machine.
It works but I wouldn't want to use it as there are problems.
But it should be good enough for you to open and save your old job.
However 10 will only open files back to 6.5.
So if you do have a 6.0 file then you will need 9 or before.
There are file converters here that will run on your machine.
Version 9 is there.
http://www.graphisoft.com/downloads/fileconverter.html
They don't need to be installed - just download and extract.
Version 9 is there.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-07-11 05:24 AM
‎2013-07-11
05:24 AM
I have the AC8 disk and an old computer Pentium 4 HT
I'm going to see if I can install it and use with my old meterd wibu key
that should still have 98 hours on it..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-07-11 05:32 AM
‎2013-07-11
05:32 AM
If I can open it in 8 I think I can save there and then jump to 12...
I think?
I think?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-07-11 05:55 AM
‎2013-07-11
05:55 AM
Version 12 can read 8.1 files but not 8.0.
See this page for a list of what can read and write which versions and also what protection keys you need (towards the end of the page).
http://www.archicadwiki.com/ArchiCAD%20versions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-07-11 08:01 AM
‎2013-07-11
08:01 AM
Thank you,
I got it up to ArchiCAD 12 On my old computer And now I will open it in 14 on the new computer, Should be able to get it up to 17 from there.
Best,
Best,
