Help with SEO
Achille Pavlidis
I have a wall which ends on a slanted column. I want to eliminate the triangular part that is exceeding of the column. But i cant find the way to do it... Tried with SEO, but no luck...
Please see attached image. How would you do it?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Hi Achille,
Have you tried increasing the priority of the beam (or increasing the intersection group number of its layer) ?
Hope that helps,
Adrian Tudoreanu
P.S.: Just to be sure: you are using subtraction with upwards extrusion; operator - the beam; target - the wall.
Achille Pavlidis
Problem solved!
Thanks, Adrian!
