Help with complex wall/window
Hello everyone, i need some help, can anyone tell me how can i do windows like the ones in the elevation i attached?
And how can i do openings like that ones in the walls?
Is that possible?
I made those with lines on elevation and made the rest on phothoshop, but since its not done in archicad i cant do renders cause i dont have the windows like that.
I thank you in advance for all the help, i hope someone can lead me in the right path on how to do that.
2 Replies 2
Pretty easy.
For actual windows, which behave as windows, schedule, etc., see this article (and many threads here for 'custom windows'):
http://www.archicadwiki.com/CustomShapeDoorWindow?highlight=%28custom%29%7C%28window%29
and this summary tip linked from there:
http://www.facebook.com/photo.php?fbid=426037663042&set=a.426037433042.204952.191457003042&theater
For schematic design when things are fluid and you want your shapes to be easily changed just to show an idea, try Dwight's idea here:
http://www.archicadwiki.com/CreateCustomWindows?highlight=%28custom%29%7C%28window%29
Have fun. Post your results. 😉
Hi Karl, i tested one of the solutions you proposed and it seams to work! When i have more free time i will test the rest.
Thank you for your help, i will post the results when i finish the work.
