We value your input!
Help with *.dwg Line thickness in Archicad
I imported a *.dwg file of a OS map. The lines are too thick to even read the drawing. (see pic)
What am I doing wrong?
10 REPLIES 10
Just a little tidbit, from an Autocad user of 9 years....
Not everyone sets up their drawing the same way....
Your lines were probably thick because they setup their lines to be a given thickness, rather than having a color setup to be the thickness they need, and keeping the lines at a thickness of 0 (Glad Archicad has a Thin Line setting )
Best thing you can do is have then print out their layer manager/and or plot format file. If you do your work with the same people each time, and they (hopefully) use the same layering system, you can set up a template that will convert everything to your specs.
