Hidden object lines for elevations
If I'm working with elevations, why in the world of Archicad would they not make it user friendly to make structures behind cut surfaces to have an option to dash/ghost/ or hidden line the structure behind the cut surface. Does anyone know if there is an option to do this?
Thanks for reading!
greener
4 REPLIES 4
Hi Greener,
Something like this was discussed a couple of days ago. Try here -
http://archicad-talk.graphisoft.com/viewtopic.php?p=140968
I assume it works in elevations also. You may have to try it and see!
Hey Peter thanks for the forward greatly appreciated! I looked through the previous threads on this issue and "Special Menu" always comes up, I work with AC 12 and I cannot for the life of me activate this menu for some reason, any suggestions?
Thanks
greener
Sorry for the delay.
The procedure is slightly different depending on the OS, so here are some links for both Mac and PC that may help -
http://www.archicadwiki.com/Special%20Menu
http://www.archicadwiki.com/TechNotes/Add%20Special%20Menu%20to%20Registry/Work%20Environment
Peter,
Thank you very much for your support. Thank You!!
-greener
