Hiding Windows/Door objects only when Core Structure Display
Hi People, with no preambles, this is what is taking too much time by self to figure it out.. Can you help me?
Windows and Doors are shown in 3D view when I am in Core Structure Display.
But they are not Core, and they are not load-bearings, how ever I can't figure it out to disable them.
Reading in the forums the option is to disable them with "Filter and Cut Elements in 3D" but this also disables it from "Entire Model" view
Any idea?
5 Replies 5
You can save each as a separate View (one view with doors/windows and one view without) and switch between them.
Richard
AC26 (since AC6.0), Win10
Hi.
Good enought for drawings. Thanks
But they continúe as not-core and not- bearing... in an incorrecto filtering option.
A similar question is that. A complex wall composed of a core of lightweightbconcrete blocks and reinforced concrete as a beam and some finshings, can not be set to display only the estructural load material which is the reinforced concrete.
I could set up the lightweightbconcrete as Other, but then It will get filtered out of a coreonly display in and layout or drawing.
Is there any chance of modifying some scripting language to get this working?
I wonder, if nobody suffers it.
Or, I am facing a product of my own newbism.
I am attaching an example picture.
Core of Load bearing objects is showing an incomfortable view of all object on the scene.
This has to be incorrect.
Is it normal ????
Ernest Atanasiu
Try filtering the objects in the 3D view.
View/Elements in 3D View/Filter and Cut Elements in 3D...
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
