Hiding levels
Hi all.
Is there a way to hide everything above the ground floor, or hide everything apart from the second floor etc so that I can render out sections? I know I could save files out with everything else deleted, but surely this must be an option already?
Regards.
Andrew.
Ignore me I found it!
There are two ways to limit the 3D view vertically:
1. Go to: View > Elements in 3D view > Filter Elements in 3d. This allows you to chose which stories to view in 3D.
2. Go to: View > Elements in 3D view > 3d Cutting Planes. This allows you to cut through the model at any elevation (and angle etc.)
These methods can also be combine to, for example, show a cutaway view of a single story.
