History log
is there history log in AC10? like History palette in photoshop.
so i can pin point the stage i want to go back (undo).
1 REPLY 1
If you have Special Manu (you mast regedit) in manu bar you'll find something like history but it's only to observe & set undo limit up to 99, anyway U can only undo step by step with Undo/Redo command from Edit Manu.
Hope this attach.helps you
ps. To enable Special Manu U must search forum for instructions
