Hole in a Mesh?
Can one make a hole in a Mesh short of using SEO? If we can do it for a slab why not a Mesh?
Thanks,
joseph
6 Replies 6
Stress Co_
You can.
Select the mesh.
Select the mesh tool.
Set the mesh tool to a polygon.
Select the "insert new node" from the pet pallet.
Start drawing your hole. When you get to the starting node of the hole it will prompt if you want to create a hole or add new points.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Wow, thanks,
I really like the add the new Points option; it can save a lot of time adding points. Guess ArchiTerra is not needed any more.
Thanks Again,
Joseph
p.s. any other hints on Mesh tool is very much wecomed.
Stress Co_
Another user shared his mesh tool notes with me...if he doesn't mind... I'll forward it. It helped me. (thanks Peter)
Thanks (Marc & PETER), looking forward in seeing & using it.
Joseph
Hello Marc,
I don't mind at all.
I hope you fixed some mistakes
and made things clearer.
Peter Devlin
Stress Co_
Joseph:
Check your ArchiCAD-talk messages.
Mistakes They only one's I found were the one's I made.
This is how s c r e w e d up I was on cutting meshes: (left side)
