Hole left in wall
I just removed a column going through a wall. Now it seems that the "shadow" of the column is still left. When adding new walls the same hole for the old column still exists. I've tried "rebuild" and "redraw" with no luck. Restarting doesn't help either. I need help.
I am using AC10 on Xp.
Is it possible that there is a copy of the column on a hidden layer?
Thank's a lot! Problem solved.
