Hole through amorphous shape
Hello again. Now I have my shape with a thickness, I now want circular holes through it Any ideas? I can make rectangular holes in rectangular slabs but not circular ones in irregular slab. Any ideas>
1 Solution
Lingwisyer
Guru
Same way you made the slab. Draw a circle/shape over your slab. Select the slab. Magic wand the circle/shape.
You can also change to the subtraction option while the slab is selected then just draw your hole.
Pretty sure this is all in the beginner documents.
Magic Wand: https://helpcenter.graphisoft.com/user-guide/76364/
Ling.
Go to post
3 Replies 3
Lingwisyer
Guru
Ling.
Thats what I thought but it didn't seem to work. I'll try again and look at that link. Thanks
Thanks Ling - the link to Help did it.
