Hotfix-5 for ArchiCAD 12 (build2675)
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Dear AC-Talkers,
Hotfix-5 is now available for INT, AUS, NZE, AUS localized versions of ArchiCAD 12. You can download the Hotfix through the Help menu/ Check for Updates command. You can find a list of fixed bugs in the Release Notes.
Gergely Kmethy
22 REPLIES 22
Bob Moore
I attempted to install the Hot Fix 5 three times today and each time the installation failed. Has anyone else had this problem?
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
Rakela Raul
no problem here
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
everything ok here to.
Are you trying to install it with ArchiCAD still open perhaps?
Bob Moore
Yes, I closed AC before installing. I followed the instruction on the read me first page. I even downloaded the fix a second time and tried it again. It got to the 63% mark on the install, then it flashed a message that the install had failed.
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Greg doesn't mention that this is for the US version. Could that be an issue?
Richard
AC26 (since AC6.0), Win10
Bob Moore
I am using the US version. I notice that everyone that has replied are using a windows version.
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Bob Moore
I tried it again and after three relaunches it installed.
Thanks
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Rick Thompson
Mac here, and all fine.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
