Greg Kmethy
Hotfix for ArchiCAD 10 is available
Dear Talkers,
It's time to visit the Help menu / Check for updates command to get the latest Hotfix for ArchiCAD 10 (build 966). Please check out the Release Notes for a fixed bug list.
The patch applies to both Education and full licences of ArchiCAD 10. The patch also updates goodies installed in the ArchiCAD folder
Gergely Kmethy
VP, Customer Success, Graphisoft
43 Replies 43
MarinRacic
Where's the hotfix for ANY kind of Mac anyway? I got this screenshot when I tried to find and download the update.
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
Jefferson
Hi Gergely -
Where can I find release notes covering the items addressed in the Hotfix?
edit: never mind found it............. was this here over the weekend or just my poor powers of observation?
Thanks -
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Jefferson wrote:
release notes
Here, but the bugs are here.
Hi Marin, the USA link is still working fine, couldn't say about the INT.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Jefferson
Hi James -
Thanks, found it right after posting, of course.........I am a little ginchy about installation after following along this thread. Haven't pulled the trigger just yet, maybe at the end of the day and some more work completed.
Stuart, any more word from your reseller?
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Hi Jefferson
No more word yet. It may be that they (CadImage) are trying to sort things out with their tools, which are widely distributed here in NZ with the standard installation. It sounds like there are a few issues with various tools doing weird things. So I may have jumped the gun a bit with my advice not to update. Maybe someone from CadImage could clear that up here?
Cheers
Jefferson
Thanks Stuart!
As mentioned earlier, I'll finish up the day's work anyway before giving it a go. It's all probably good or we'd have more noise by now! Might here from Link once he's up and about.
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
MarinRacic
I guess on the other side of the Atlantic software works better!
Still waiting for an answer from GS though...
AC ...20/21
www.3Dart.hr
STRANGE.. When I run it - it can't find my installation of ArchiCAD. Then when I browse for ArchiCAD 10 - the dialog box won't allow me to select the greyed out application.
I have tried it both ways - with ArchiCAD running and not.
__archiben
have you renamed the folder or application to anything other than its defaults:
./Applications/Graphisoft/ArchiCAD 10/ArchiCAD.app (the ".app" bit is usually hidden by the finder)
. . . when you search for it you only need to click the 'choose' button when you've selected the archiCAD 10 folder . . .
make sure archicad is not running!
HTH
~/archiben
b e n _ f r o s t
Greg Kmethy
The INT Hotfix (966) is available again. 999 was just a mistype.
Gergely Kmethy
