Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Hotfix for ArchiCAD 11 (build 1033)
You can now download the first Hotfix for ArchiCAD 11. (it's build 1033). Currently the INT, USA, AUS and NZE language versions are available.
ArchiCAD automatic "Check for update" will notify you about the Hotfix, but the "check for updates" command in the Help menu is still available.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
12 Replies 12
TomWaltz
mariogomezcervantes wrote:
Hi guys:
Got the Hotfix, download it, when it start running, it asks me for the archicad file, I tried the one inside graphisoft, dosent work, so which folder is it looking for?
Thanks.
Mario.
What OS are you using? (It might be worth adding to your signature so you don't keep getting asked that question)
Tom Waltz
Hi guys:
Thanks.
Mario.
ArchiCAD 11 on a Pentium 4 - xp sp2
It should be asking about a folder, not a file. In any case, unless you installed AC 11 more than once in more than one folder (no reason to!), simply accept the defaults - do NOT browse/etc - and the update should proceed normally.
If not, the easiest thing (in terms of time) is to uninstall AC 11, then reinstall and install the hotfix.
Karl
