AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Hotfix for ArchiCAD 13 (build 3600)
Dear Talkers,
The next Hotfix for ArchiCAD 13 INT version (build 3600) is now available. You can download it through the Help Menu's "Check for updates" command. Further language versions will be released soon. This Hotfix will update ArchiCAD, the BIM Server, the BIM Server Manager, and other ArchiCAD components, like the C4D Add-On and goodie tools.
Teamwork users: Make sure that the BIM Server and all the ArchiCAD clients are updated at the same time!
Please take a moment to read the release notes:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC13-3259to3600-ReleaseNotes.html
Best Regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
10 Replies 10
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
KRUChY wrote:
I have AC SE 2010 POL version, and i can't install any of your hotfixes for Java Problem.
AC13-3826-Hotfix7 or AC13-3826-JAVA-PATCH-GEN don't want to install !!
Any help??
Dear KRUChY,
Sorry for the problem.
One of my colleagues will contact you very soon with a custom solution for you, because the patch for the SE version in its installable form is being made but it is not finished yet.
Best regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
