AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Hotfix for ArchiCAD 13 (build 3600)
Dear Talkers,
The next Hotfix for ArchiCAD 13 INT version (build 3600) is now available. You can download it through the Help Menu's "Check for updates" command. Further language versions will be released soon. This Hotfix will update ArchiCAD, the BIM Server, the BIM Server Manager, and other ArchiCAD components, like the C4D Add-On and goodie tools.
Teamwork users: Make sure that the BIM Server and all the ArchiCAD clients are updated at the same time!
Please take a moment to read the release notes:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC13-3259to3600-ReleaseNotes.html
Best Regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
10 Replies 10
Hi Andor,
I get the message that my ArchiCAD build 3259 is up-to-date. No download shows up...?
Edit: DUH. I missed that you said "INT". Assume localized versions will roll out over the next couple of days?
Thanks,
Karl
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Hi Karl,
I will make the "INT" word bold.
Regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
Achille Pavlidis
Hi, i'm facing serious problems with the BIM server.
Please see here: http://archicad-talk.graphisoft.com/viewtopic.php?t=32656
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
GAG
While installing hotfix 3600 (AC13-3600-HOTFIX6-WIN64.exe) on 64 bit Windows 7 to update 64-bit ArchiCAD 13, I get this error just after launching update:
Java Virtual Machine Launcher
Invalid or corrupt jarfile W:\Windows\Temp\-1476916033\archive.jar
OK
  • File "archive.jar" exists in specified location, but has zero size.
  • All previous updates installed ok without errors.
  • I redownloaded update again, but got same error.
Currently, problem is solved, but I don't want to download file again when I doubt if it's corrupted.
I want just verify file checksum, like this:
SHA-1 of AC13-3600-HOTFIX6-WIN64.exe: 6e1a2dce06dfd0980d5ee121c827f4d2b59333c4
So, my wish:
Add cheksum info to all releases with file size > 100 MB
There is free open source shell extension to verify file checksums on Windows:
HashCheck Shell Extension
Screen:
Mac OS X has built-in support:
Mac OS X: How to Verify a SHA-1 Digest
Example of download section at hotfix page:
Download this Hotfix
George
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
GAG wrote:
So, my wish:
Hi GAG,
We will consider your suggestion. Thank you for the idea.
Sincerely,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Dear Talkers,
It turned out that when trying to hotfix a BIM server the installer runs into a problem on MAC's if the user who is doing the installation is not a Local User. There is a work-around on how to avoid this problem before the installation. Here you can find the work-around:
http://www.archicadwiki.com/Bugs/HotfixingAC13BimServerOnMacRequiresLocalUser
Best regards,
Andor
AndorSzőke
Product Management
GRAPHISOFT SE
Like Karl's post earlier, my AC13 still says it is up to date with Build #3259.
Would that mean it's not necessary for AC USA users to download and install the #3600 Hotfix? Would there be any issues if we did anyway?
I believe in "if it's not broken, don't fix it" so if my AC13 is not telling me it's outdated, I will leave it alone.
The opening post says this is the INT hotfix.
I guess now that they found those problems they make sure those are fixed before releasing other language versions.
I have AC SE 2010 POL version, and i can't install any of your hotfixes for Java Problem.
AC13-3826-Hotfix7 or AC13-3826-JAVA-PATCH-GEN don't want to install !!
Any help??
