Hotkeys
Hey guys I need help with this........
There is something wrong with my hotkeys, for example, when I press Ctrl+C its not copying the selected thing, or if I press Ctrl+V its not pasting the copied or cutted item, or if I press Ctrl+Z its not undoing the last thing I did, or any other thing with hotkeys is wrong.
My damn version is russian, but if you tell me what to do in english, I can find it out...
1 REPLY 1
Eduardo Rolon
Check your keyboard shortcuts in your Work Environment. This is assuming that the problem is only in AC.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
