Hotlinking Disables the Rooftrims and Solid Extraction!!
Archicad 17:
Please help! When the hot module (hotlink) is attached to a new project I lose all my roof trims. The hotlink is attached floor by floor and not multi-storey because it is not possible in my case. I hate that you cant attach a multi-storey as an self contained Xref !!
But that is not the issue here, the loss of roof trims and solid extraction is!
I assume that the walls and the roofs trimming them are on different stories. SEOs are not maintained when stories are linked independently. There are (at least) two ways to work around this.
One is to use the "Trim to Roof" command in the source file which inserts the cutting plane into the definition of the walls and is not dependent on keeping the relationship between the walls and roof as SEOs do.
The other is to redo the SEOs in the linked modules. You can select elements in the module when the group function is suspended and add them as targets and operators for the SEOs. It's been a long time since I used this but I assume it would still work.
Of course it would be lovely if GS were to enable linking multistory modules and retain their original story height settings. This has been requested early and often and doesn't seem like it would be hard to implement but... Oh well.
Even roof trims is lost...
David Maudlin
What was called "trim" in earlier versions is now referred to as "crop", in the Help files see: Virtual Building > Construction Elements > Roofs > Crop Elements to Single-plane Roof.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
