How Do I rotate an object
Hi I have created a serious of profiles to make up a chair and I want to rotate the legs and back so the stand up.. can somebody tell me how this is done.. it should be easy.
Thanks
Marc
6 Replies 6
Rakela Raul
use a modeling software
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
I dont know what you mean, what I need to do is creat a banquetting chair. So what I did was create a number of profiles for the legs the back the seat etc. Since these profiles lie flat on the floor I need to stand some of the up like the legs and the back, then just orientate all the objects in the right position a group them together.
My problem is I can figure out how the stand up the legs!
Regards,
Marc.
Create the profile standing up... Go to the Help menu/ArchiCAD Help; click on the Search tab and type in Profiler. Complete instructions for using Profiler are there and it will tell you how to easily accomplish what you are attempting to do.
Remember... THE HELP MENU IS YOUR FRIEND!
Woody
Regards,
Marc.
Marc,
ooops...I belive you meant for this post to be here http://archicad-talk.graphisoft.com/viewtopic.php?t=5679
Haneef Tayob
Part of the solution may be to do some GDL editing.
Using the GDL edit to add 'rotx', 'roty' and 'rotz' to the objects may help in rotating some parts.
I sometimes wish that these 3 rotate related items were added automatically to any custom object created (will post it on wish list)
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
The profiles that you created, are they actual objects or are they a series of slabs walls etc. shaped into the profile you require?
If they are already objects you may need some GDL as mentioned, otherwise...
If for example you modelled a leg flat you can look at the top of it by selecting the side view in 3D and viewing the sdie that relects what you want to see from the top and then saving this as an object.
When you open your leg in the object settings it should be vertical.
