‎2018-01-30
05:30 PM
- last edited on
‎2023-05-23
02:14 PM
by
Rubia Torres
Solved! Go to Solution.
‎2018-02-08 02:04 PM
‎2018-03-13 03:17 PM
‎2018-03-13 03:26 PM
‎2018-03-13 06:23 PM
dkovacs wrote:Having done a lot of hotlinking with ifcs lately, I am thinking that when hotlinking an ifc, you do not select an ArchiCAD template, but a translator. Does the translator then use the default settings of the ArchiCAD file it is referenced from?
Hello Mats_Knutsson,
It is indeed controlled by the Morph Default Settings, but not necessarily in the file you are working in.
In ARCHICAD 21 you need to select a Template file for hotlinking. This can be (and most of the time it is) the Default ARCHICAD template, but you can basically use any file. During import, ARCHICAD uses the Morph tool defaults from this template, so if that has a floor plan fill like that, it will import with those settings. (If you choose the file you are working in as your template, then the last saved state of the morph tool default should be used).
I hope you will be able to solve your problem with this info.
Regards,
‎2018-03-23 01:56 PM
Karl wrote:Dear Karl Griffith,
‎2018-03-23 04:48 PM
dkovacs wrote:Thanks, Daniel. I didn't realize that.
So yes, you are actually selecting a translator from a template file, and thus selecting both a translator and a template at once.
Regards,
