How can I change default story linking in 3D?
Mats_Knutsson
Mentor
I want to change the default to "By elevation" when z-dragging elements in the 3D view. Possible?
Br,
Mats
AC 25 SWE Full
5 REPLIES 5
Tim Ball
Right click and change storey
Tim Ball
AC26, iMac
User since V5
Mats_Knutsson
Mentor
That's what I don't want to do. I want "by elevation" to be the default so I just can drag stuff upwards/downwards without having to manually change story belogning.
AC 25 SWE Full
Mats_Knutsson wrote:
That's what I don't want to do. I want "by elevation" to be the default so I just can drag stuff upwards/downwards without having to manually change story belonging.
I believe dragging in 3D will keep the current home storey unless you amend it as Tim suggested.
I don't think there is any option to change this functionality.
Cutting & pasting in the floor plan between storeys will change the home storey.
Mats_Knutsson
Mentor
Suspected that. Have to deal with elements not showing up ... One of ArchiCADs most appealing features is working in 3D...sketchup style.
AC 25 SWE Full
jl_lt
Ace
I made a wish about this elsewhere. The default opction should be what mr. Mats suggests, because it's very annoying to manually change levels (it does work when one uses the multiply command though).
One should also be given the option to define a range (i.e. object placed 5cm below level line still belongs to that level)
