How can I mirror an Object and a morph on Z axis?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-04-17
02:05 PM
2023-05-24
10:33 AM
Rubia Torres
Hey guys , I found a problem. How can I mirror an Object and a morph on Z axis? Thank you.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-18 01:36 PM - edited 2022-04-18 01:40 PM
but I can't mirror morph in the elevation/section. When I use mirror and click in the elevation/section view, it always mirrored left and right, not up and down (Z axis)
Or only I can do is mirror it in the same elevation and rotate the new one 180° and move it up to the original one??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-18 08:20 AM
For objects it depends but for morph on the other hand you can go to 3d view and mirror from there or you can create an elevation/ section view then mirror from there. 😎
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-19 03:33 AM
surprisingly you can't mirror a morph you can only rotate and mirror it then bring back to the same location or your preferred axis point. 😐
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-19 03:13 PM - edited 2022-04-19 03:21 PM
yeah, I can't make it. Can you show me a GIF or some op videos. I use mirror function, and want to drag a mirror line, when I first click the view, they mirrored side by side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-20 03:46 AM
This is the way you can do it a bit of a work around...
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-04-20 04:36 AM
OK, Thank you for your reply. So you can't mirror morph on z axis directly either, haha. I am balanced.😁
